S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   CEL no boost? (https://www.s2ki.com/forums/s2000-forced-induction-142/cel-no-boost-302876/)
twelv Jun 26, 2005 05:01 PM
CEL no boost?
Would the primary O2 sensor affect my car going into boost?
I already bought a new one I will install it on monday.
I have a stock Vortech SC on a 2000 S2K.
Slows2k Jun 26, 2005 07:48 PM
What code do you have?
twelv Jun 27, 2005 04:44 AM
I forget but it says something along the line that the Primary O2 sensor is shot and I need a new one.
Slows2k Jun 27, 2005 03:08 PM
You really need the DTC # before determining if it would effect driveability.
twelv Jun 27, 2005 07:00 PM
OK I will try to find the piece of paper with the codes written on it.
twelv Jun 28, 2005 05:46 PM
primary HO2S heater circuit problem
Slows2k Jun 28, 2005 06:51 PM
A P0135( HO2S1 Heater failure) Won't have any effect on the car going into "boost".
hackmac87 Jun 28, 2005 07:38 PM
no the o2 sensor just wont be as acurrate. boost for s/c cars is based entirely on rpm and air flow/boost consumption of the enigne.
twelv Jun 28, 2005 07:40 PM
that is what I thought I will need to take my car to a shop and see what has happen to the SC. I just had a new clutch installed and since then the o2 sensor light has come on and I can't build enough pressure to induce power.
everything on top looks to be plugged in.
twelv Jun 28, 2005 07:42 PM
I must have a leak some where I need to check my belts as well to make sure they are tight enough.
© 2026 MH Sub I, LLC dba Internet Brands
