CEL no boost?
Old Jun 26, 2005 | 05:01 PM
twelv's Avatar
Default CEL no boost?
Would the primary O2 sensor affect my car going into boost?
I already bought a new one I will install it on monday.
I have a stock Vortech SC on a 2000 S2K.
Old Jun 26, 2005 | 07:48 PM
Slows2k's Avatar
What code do you have?
Old Jun 27, 2005 | 04:44 AM
twelv's Avatar
I forget but it says something along the line that the Primary O2 sensor is shot and I need a new one.
Old Jun 27, 2005 | 03:08 PM
Slows2k's Avatar
You really need the DTC # before determining if it would effect driveability.
Old Jun 27, 2005 | 07:00 PM
twelv's Avatar
OK I will try to find the piece of paper with the codes written on it.
Old Jun 28, 2005 | 05:46 PM
twelv's Avatar
primary HO2S heater circuit problem
Old Jun 28, 2005 | 06:51 PM
Slows2k's Avatar
A P0135( HO2S1 Heater failure) Won't have any effect on the car going into "boost".
Old Jun 28, 2005 | 07:38 PM
hackmac87's Avatar
no the o2 sensor just wont be as acurrate. boost for s/c cars is based entirely on rpm and air flow/boost consumption of the enigne.
Old Jun 28, 2005 | 07:40 PM
twelv's Avatar
that is what I thought I will need to take my car to a shop and see what has happen to the SC. I just had a new clutch installed and since then the o2 sensor light has come on and I can't build enough pressure to induce power.
everything on top looks to be plugged in.
Old Jun 28, 2005 | 07:42 PM
twelv's Avatar
I must have a leak some where I need to check my belts as well to make sure they are tight enough.
