Changing oil in Comptech'd S2k
Old Mar 1, 2005 | 11:24 AM
Ckcrigger's Avatar
Default Changing oil in Comptech'd S2k
Old Mar 1, 2005 | 12:44 PM
gfacter's Avatar
Originally Posted by Ckcrigger,Mar 1 2005, 03:24 PM
I tried calling Shad at Comptech a couple times, but he's not in and not returning calls.
The Comptech S/C uses the drain bolt to feed oil to the charger.
If I was to get one, is there anything different I'd need to tell the Honda dealers about changing the oil so they don't screw up the oil line?
Or will they figure it out.
So the question is: how different is changing the oil on a Comptech S/C'd S2k and do I need to tell them to take extra care with the oil line to prevent damage?
I would be careful with this one, the oil line uses a AN fitting (a 8AN I think). You don't want some oil change hack buggering up the fitting.
I bought a some of the aluminum AN wrenches to use on the fittings. You may want to get them also and supervise the oil change.
DJSang
Oct 21, 2007 06:31 PM
ihavenosn16
Oct 1, 2006 12:25 PM
JROSEN
Apr 11, 2005 11:14 AM
FormerH22a4
Mar 8, 2003 04:22 PM
