clicking noise at idle
Old Mar 29, 2007 | 10:29 PM
j66's Avatar
j66
Default clicking noise at idle
i just brought my car back out, and when i start the car, there is clicking noise from from near the belt at idle. is been a whole winter, i didn't remember if i had this before. is this normal? or anyone have any idea what that clicking noise is?
hope you can help me out, the car drives find, just the ignoring click noise at idle
Old Mar 29, 2007 | 10:39 PM
Spec_Ops2087's Avatar
hmm clicking isn't very descriptive, need a video
Could be the belt tensioner (which is known to make a ticking noise) but it could just be the injectors as they tick at idle.
Old Mar 29, 2007 | 11:13 PM
j66's Avatar
j66
thanks, i'll try to get a video up tomorrow!
Old Mar 30, 2007 | 12:13 AM
jdnissanz's Avatar
I got the same problem IDK honestly if it is a problem or not, but car drives AMAZING. I am building soon, but wanna know if the motor is ok still. Not stealing post just wanted u to know ur not alone.
**Side not what A/F are you or anybody running when on normal throttle such as sixth gear 3K RPM, I wanna know if I am in normal range or if the range is not important until WOT** Sorry tell me to remove side note if it takes away from original post.
James D.
Old Mar 30, 2007 | 12:38 AM
news2kroller's Avatar
I have the same issue, it is not the timing chain tentioner or the cam gears, the car has been in the shop for a week with no answers. Mine only occurs well into operating temps (160+ water temp for 10 minutes or more. does this sound similar to your problem. I hope i get an answer soon and maybe solve your problem too. good luck.
Old Mar 30, 2007 | 05:27 AM
pushin9's Avatar
I think I have the same sound too
Old Mar 30, 2007 | 05:31 AM
OGPackin's Avatar
It could be you need a valve ajustment...??
Old Mar 30, 2007 | 08:10 AM
shop did another valve job for me (second in 4k miles) to see if that would solve it...no luck for me
Old Mar 30, 2007 | 12:05 PM
Spoolin's Avatar
Are you running crank vents?
If so, it's just the suction causing the rubber off the tips of the sparkplug wires in the cylinder head to make a bobble noise.
Old Mar 30, 2007 | 12:29 PM
pushin9's Avatar
I have crank vents.
However that doesn
