Clutch Install with Vortech S/C
Old Jan 18, 2016 | 08:47 PM
skinsfn36's Avatar
Default Clutch Install with Vortech S/C
Hey there,
I just got finished up installing my Vortech supercharger and was saving the clutch for last. I started to realize that the crossmember might make the clutch install pretty tough with the supercharger unit as close as it is.
Have anyone done a clutch install with a Vortech or SOS supercharger in place?
Thanks
Old Jan 21, 2016 | 05:46 PM
steven975's Avatar
People have reported that they've done it, though it was unclear if they dropped the subframe, which makes the job a lot less time-consuming.
I think if you have to drop the subframe, there's no room for the blower to lower due to the cross member. Really, removing the SC isn't that time consuming.
Old Jan 22, 2016 | 12:40 AM
riceball777's Avatar
I don't see how it possible. You have to lower the subframe 3 inches to get to the top transmission bolts. Your cant lower the subframe with the supercharger bolted on due to crossmember.
Old Jan 22, 2016 | 05:27 AM
iDomN8U's Avatar
Did it, you will have to drop the subframe.
Take your time, you'll have plenty of room just keep your eye out for it as you lower, for me it was the valve cover was hitting the firewall before the supercharger hit the crossbeam.
Plenty of room..
Old Jan 22, 2016 | 05:53 AM
Chance S2K's Avatar
Just to reinforce what everyone else has already said: Yes, you have to drop the subframe. It's impossible to get to the bolt on the top of the trans housing by the firewall without it.
Old Jan 25, 2016 | 06:57 PM
joes sled 2000's Avatar
Yes it can be done at least with a Vortech . I did one for a friend a few years back . The charger does rest against the brace though . I padded it and it worked out ok . It was harder than normal as i couldn't drop the engine as low as i usually do . I think it's best to spend 15 minutes and remove the blower . This way there's no chance of damaging things . The SOS charger is much easier to remove than the Vortech unit so that would be a no brainer .
vteconly
Oct 25, 2008 09:26 AM
Reaper 6A
Sep 1, 2007 07:51 AM
Partshelper
Oct 26, 2006 12:03 PM
Y2KS2000
May 19, 2005 11:59 PM
J.T
Nov 9, 2003 07:29 AM
