Cometic-2mm 3mm or inline
I just got off the phone with cometic about there HG, the stated the 2mm is a 5 layer piece and the 3mm is a three layer piece. I have read that inline is a 3 layer as well. I also asked if they were any differnces in strenght and he said no. I have been debating this for some time and would like to use the 2mm. Many posts seem to be older and I don't know if there product has changed.
If I go with the 2mm do I need to change the cam gear? Max boost to be safe.
If I go 3mm should I go IP or Cometic or are they the same? Max boost to be safe.
Goal is 400hp, gt 30, greddy ult
Thanks,
Thanks,
I had the cometic 3mm on and it blew between number 3 and number 4. It was on for less then 1200 miles. I have had the IP since with no issues and have been on it with more WHP and for alot more miles.
I would also like to hear from people witht the 2mm and see if they changed there cam gear or not.
My 2mm Cometic is 4 layers not 5
While you probably don't have to clock the cam gear I did.
I've read the Inline gasket is a basically a metal spacer with an OEM HG on the mating surfaces.
While you probably don't have to clock the cam gear I did.I've read the Inline gasket is a basically a metal spacer with an OEM HG on the mating surfaces.
Originally Posted by Revenge' date='Jan 1 2009, 04:52 AM
How long ago was it since your HG blew?
Originally Posted by ChefJ' date='Jan 1 2009, 04:14 PM
It was there latest design if thats what you are wondering. I still have it laying in the garage.
Ewwwwwwwwwwwwww. I guess that leaves me with the 2mm and the in-line pro. I have not seen to many people with blow 2mm ones but have read a few posts with 3mm cometic ones.
