Cometic Head Gasket suggestion
Dear everyone
haha,
I am running the 3.2" pulley by science of speed on my ap2. The pulley is roughly 11-12LBS of boost on the 2.2L. It was suggested to get a lower compression headgasket. They suggest running a .74" thickness while the stocker is .30" . It would lower compression 9:8:1 which is damn low for this car. Please advise for you guys boosted higher on Supercharger kits if you did this or ran like a .45" or .50"?
Eddie
haha,I am running the 3.2" pulley by science of speed on my ap2. The pulley is roughly 11-12LBS of boost on the 2.2L. It was suggested to get a lower compression headgasket. They suggest running a .74" thickness while the stocker is .30" . It would lower compression 9:8:1 which is damn low for this car. Please advise for you guys boosted higher on Supercharger kits if you did this or ran like a .45" or .50"?
Eddie
i ran a 3inch pulley (14psi) with a 3mm headgasket. I made around 370-380whp with a stock header, and berk 63mm testpipe and tlr 63mm single. The torque actually started to taper off around 8500rpms on my setup. In hindsight, i probably would have run a 9.8:1 setup like yourself!
another guy with a similar setup, with the main difference being 2 less pounds of boost made 390whp, but less torque!
Originally Posted by Danks2k,Apr 2 2008, 01:20 PM
In the process of installing a 2mm with 3.8" vortech pulley myself. Seems like the best compromise between reliability and power.
Originally Posted by Danks2k,Apr 3 2008, 07:02 PM
3.8 should get 13-14psi but that all depends on individual setups. The 2mm headgasket will yield a 9.8:1 compression on both the F20 and F22
Would this be beneficial running 10-11 psi? with a supercharger
