Compression Recommendation
Hello crew! I have a questions that I hope can get answered by you all. My pistons took a crap and messed my motor up. I am in the process to get it honed. Maybe a .20 or .25 not sure what's best. In addition I need to get pistons so I wanted to know how much boost can I run if I get low compressions pistons that will run 9:1. Also how about 10:1. Which one should I even run, I was thinking 10:1 since I can't run that much higher boost with the log since I must mess with the timing due to heat, what do you guys think?
A little info about my basic set up. It's pretty much a hybrid greddy kit running a log t3 pfab mani. With a gt3076r turbo..
I tried searching however it seems my situation is a bit unique I guess since its not a popular one. Thanks guys in advance for your help and time.
I just got mine rehoned and they went .25mm bigger. Were putting 87.25 / 9.5:1 Mahle pistons in. The car will be turbo. When you go aftermarket pistons though, you'll need to go aftermarket rods. I opted for the Crower rods. Block is solid now.
