Compression test results 160-160-160-110
Ok, so i finally got my head back on and did a compression test today.
160-160-160-110
Engine hasn't been run in 9 months..... I remember reading something a long time ago, where a guy imported an engine for in nissan or something, and compression was really uneven. Then after running the car, compression was perfect.
I put oil in the 4th cylinder and it jumped up to 180ish....
Input appreciated....
I'm in the final stages of finishing my turbo project, and i'm concerned with the compression results..... Hopefully somebody has something to say that will make me feel better....
160-160-160-110
maybe you should try to do the leak down test, so you can find out what might be causing the problem. and if you put the oil and if the reading went up doesnt that mean you have leak around the rings??
Originally Posted by Slows2k,Jul 3 2009, 07:40 PM
The compression test needs to be done on a engine at operating temp
What are stock compression numbers for the S2000?
Yeah you need to do the test with the engine at operating temps.
When it heats up the rings will expand, giving better results.
This being said, I'd imagine after 9 months of sitting that your compression would be pretty low.
