Compressor Surge?
Old Mar 30, 2011 | 11:22 AM
S2KSUPERCHARGED's Avatar
Default Compressor Surge?
Hey guys,
three questions:
1) Should my TIAL Q BOV be open during idle?
2) It flutters when I switch gears while in boost, does that mean my spring is getting worn out or not heavy enough (used BOV)?
3) What size spring should I get if it is the spring, (I am running 20psi on a 9:1 compression)?
Thanks, The new search engine has not been helping me lately.
Old Mar 30, 2011 | 05:19 PM
Anyone? This should be an easy answer
Old Mar 30, 2011 | 06:00 PM
redboost10's Avatar
The bov should open when changing gears. I'd it's open under idle, that is not right. The spring psi just determines the lowest wg boost you can run.
Where are you getting your vacuum source from?
Old Mar 30, 2011 | 06:10 PM
rosscoe21's Avatar
It depends on if your supercharged or turbocharged. If your supercharged, then yes it should be open at idle.
Old Mar 30, 2011 | 07:06 PM
EternalLx's Avatar
Even for a turbo it can be open under idle if your setup is efficient enough. with my turbo setup its open slightly at idle and you feel air pushing through. To OP: is it only fluttering during normal slightly in boost shifts or WOT? You could try a softer spring.
Old Mar 30, 2011 | 08:04 PM
hurtgen's Avatar
look inside it to see if the o-ring flipped over to the back of the valve and just hanging around in there. thats what happened to mine. took a needle nose and pulled it back over. no more surge.
Old Mar 30, 2011 | 08:05 PM
On idle its completely open... and its the tuner ran it from an already existing hose teed off of the hoses coming out of the intake. I forget the name.
The tuner said I should run a 9psi spring. Is that right? and yes it is turboed. it Flutters on short boost... I cant hear if it even goes off on WOT
Old Apr 17, 2011 | 02:16 PM
hurtgen's Avatar
try making the bov vacuum line independent. connect it straight up to the manifold.
Old Apr 18, 2011 | 08:21 AM
sohc_mshue's Avatar
Huh? The spring determines how much vacuum it takes to open. Whether or not it is open at idle depends on what spring you run and how much vacuum you pull.
Old Apr 18, 2011 | 10:55 AM
spectacle's Avatar
Originally Posted by S2KSUPERCHARGED
Hey guys,
three questions:
Some of the information in this thread is dead wrong. Here's the facts: http://highboostforum.com/forum/show...-your-TiAL-BOV
You should be good with a 9psi spring. If it is still fluttering, there may be something wrong with the valve itself
