Compressor surge under load?
Old Mar 8, 2021 | 02:58 AM
  #51
SuperEJ25's Avatar
Part throttle surge can often be fixed with a bypass valve setting, like a weaker spring so that the BPV doesn't fully close until higher pressure. What is your boost level when it happens?
Old Mar 8, 2021 | 11:31 AM
  #52
s2000Junky's Avatar
I think you mean a stiffer spring.
Or in the turbo smart BOV case it has a pre load setting you can adjust, Just FYI.
Old Mar 8, 2021 | 11:49 AM
  #53
SuperEJ25's Avatar
For partial throttle surging you want the BOV or BPV fully closing with more manifold pressure (closest to 0psi relative pressure) so a lighter spring and/or less preload is better.
Since the SC is always spinning, driving at part throttle at high RPM (high impeller speed) the BOV or BPV needs to be at least partially open or else you can have these low throttle surge problems.
There is a link to the turbosmart spring chart on this page:
https://www.s2ki.com/forums/s2000-fo...werks-1175850/
Charper732
Apr 20, 2019 06:49 AM
TheMuffinMan
Apr 25, 2015 11:52 PM
sfrost2287
Nov 19, 2009 12:08 PM
j_c_a
Apr 20, 2006 02:20 PM
gusrock77
Mar 14, 2006 04:02 PM
