Comptech AFR's
The Honda ECU - the "brain" cannot cope with all the stuff you are doing out side it's design. Comptec cam up with one work round on teh sotck SC setup on a stock car. You're asking too much of it hence you can't get your AFR's right. You need an aftermarket ECU to replace it and a GOOD tuner to set it up!
I searched and searched too. You'd think this would be more common knowlegde....
Just remove your testpipe and put your cat back on until you can properly set up your fuelling with an AEM EMS or similar device. I think it would be a bad idea to go with a smaller pulley given your current issues even with the standard pulley.
should be good now.
Originally Posted by EK9MAX,Oct 22 2006, 07:32 PM
Today I put my stock exhaust/cat back in.
should be good now.
should be good now.
