Comptech AFR's out of the box?
Old Sep 18, 2006 | 11:51 AM
EK9MAX's Avatar
Default Comptech AFR's out of the box?
Ok I'm getting the local honda dealership to install my SC in a couple days here.
Do I have anything to worry about concerning my AFR's? or is it setu pperfect from comptech?
P.s what about when I install my exhaust/test pipe....?
Old Sep 18, 2006 | 12:39 PM
civicguyinva's Avatar
My understanding is:
Vortech - expect it to be lean out of the box, but you can buy recalibration kits to adjust
Comptech - expect it to be lean, but you can actually adjust it a small amount with a screw
Old Sep 18, 2006 | 12:44 PM
goldenfri's Avatar
^^ Do you mean rich? I know my out of the box Comptech definetly runs a little rich not lean.
Old Sep 19, 2006 | 09:28 AM
mikey k's Avatar
I thought they set them rich out of the box for safety and then recommend it be set on a dyno to WOT AFR of ~12.5!
Old Sep 19, 2006 | 09:38 AM
news2kroller's Avatar
My tune has the top end a little lean, but i have a test pipe, my afr's dont look to great and i need to get something to tune the afr's
Old Sep 19, 2006 | 11:28 AM
00S2K01S4's Avatar
My CTSC w/ AC was lean out of the box. I had a CT header and Invidia exhaust installed.
Old Sep 19, 2006 | 12:06 PM
goldenfri's Avatar
How lean was it running? dangerously lean?
Old Sep 19, 2006 | 12:21 PM
mikey k's Avatar
There you go!
Two set ups that are lean and not stock!
I called Comptech today to talk about fitting a Comptech and AC to a JDM car. They assured me, even with the higher compression ratio, that if I leave the car stock it will not run lean. It only leans out when you start tweaking They suggested if I'm going to tweak I need a custom ECU and map.
That's out side my comfort zone
james0933
Nov 5, 2011 03:21 PM
mrscbw
Jul 26, 2011 01:14 PM
McHeizer
Dec 29, 2008 01:17 AM
kylemonster85
Jun 16, 2007 10:11 AM
BlackRoseS2000
Sep 26, 2004 08:23 PM
