comptech esm wiring
Old Jun 30, 2011 | 12:37 AM
jonkou888's Avatar
Default comptech esm wiring
sorry guys, i dunno if i should've kept the old thread or not but i got another question.
i found this esm wiring configuration:
Comptech ESM Red Wire (Power) -> ECU Pin 19 Yel/Red Wire
Comptech ESM Black Wire (GND) -> ECU Pin 7 Grn/Wht Wire
Comptech ESM Green Wire (Signal) -> ECU Pin 17 Grn/Red Wire
Comptech ESM Blue Wire (Signal) -> To MAP Sensor Grn/Red Wire
but that didn't specify to cut the map sensor wire. after i found another diagram:
https://www.s2ki.com/s2000/uploads/g...1091513337.jpg
in the second diagram, it said to cut the map sensor wire, is that necessary? and why? and also does it matter which wire is on which end (ecu-->green-->ecu-->blue-->map sensor)?
much appreciated, Thanks!
Old Jun 30, 2011 | 01:43 PM
egprelude's Avatar
In the bold, you are essentially saying the same thing. Make sure to CUT the wire. You are intercepting the signal so the ECU doesn't see BOOST pressure signals. YES, the order matters. Green -> ECU side and Blue -> Map side.
Old Jul 1, 2011 | 04:01 AM
jonkou888's Avatar
oh...ok. Thanks for your help!
Old Jul 19, 2014 | 10:52 AM
hondacura's Avatar
Hey I'm lost in this esm sorcery. Does it save me the hassle of needing an aem ems or hontata's ecu??
joejoe3
Mar 12, 2020 01:07 PM
jonkou888
Jul 22, 2011 08:16 PM
Herbo
Nov 11, 2008 02:19 PM
KenGPW
Aug 3, 2004 04:13 AM
RT
May 31, 2001 12:44 PM
