Comptech FPR
Old Dec 11, 2005 | 10:44 AM
Trip's Avatar
Default Comptech FPR
To get the A/F on the richer side, you need to turn the adjustment on the FPR clockwise,
1)If the FPR is pre-set by comptech for a 5.5 PSI , how many clockwise turns you need for 7psi ?
2)Is there any linear maths on the adjustment. i.e 3 turns will give you 1 A/F richer and 6 turns will give 2 A/F richer and so on?
Thanks
Old Dec 11, 2005 | 01:35 PM
Slows2k's Avatar
The safe way to adjust the FMU is on a dyno. With a wideband 02 sensor, and a fuel pressure gauge hooked up to the FMU or fuel rail.
Old Dec 11, 2005 | 02:24 PM
xviper's Avatar
You cannot quantify the number of turns on the FMU with A/F ratios. This would be shear folly. Even Comptech themselves, when they do this, it is done on a dyno and confirmation must be obtained after a run. It is a "best guess" and trial and error.
Old Dec 13, 2005 | 04:34 AM
Trip's Avatar
i turned the FPR adjust knob 6 clockwise turns but still running lean. I am logging with a wideband but not on a dyno, I WOT on 3rd gear up to redline.
I will start playing with my e-manage injector map to get richer.
Thanks
Old Dec 13, 2005 | 04:59 AM
Trip's Avatar
These are the results with 6 clockwise turns A/F Graph(purple) Vs Target A/F Graph(red)
Old Dec 13, 2005 | 07:46 AM
xviper's Avatar
And there you have it - my point, that is.
On a friend's Comptech car, after the 7 psi pulley was installed at the Comtech factory, it only took 2 full turns to get the A/F right. Each car is different.
Old Dec 13, 2005 | 07:51 AM
Halo's Avatar
I think my car only took 1 turn if I recall right. It would be nice if the FPR was more elegant and had a nice dial on it like a torque wrench . You could just put the 'needle' for the amount of boost you intend to run. This just isn't how the FPR works.
BTW, that's looking a bit lean Trip.
Old Dec 13, 2005 | 11:49 AM
RED MX5's Avatar
[QUOTE=xviper,Dec 13 2005, 11:46 AM]And there you have it - my point, that is.
Old Dec 13, 2005 | 12:01 PM
xviper's Avatar
Originally Posted by RED MX5,Dec 13 2005, 02:49 PM
Did Comptech do the tuning for you?
Did the boost increase make enough of a difference to *feel*?
Is it possible to go to an 8 or 9 lb. pully without additional engine controls? Will Comptech do higher boost pullies as well?
Thanks!
This was for a friend whom I was visiting at the time and yes, it was done by Comptech at their factory NE of Sacramento. The "upgrade" gave another 20 whp.
I can't answer your last question, sorry.
Old Dec 14, 2005 | 07:28 AM
frans2k's Avatar
Comptech won't give you a smaller pulley, you have to go to Drew at Tech2's to get it. You do need larger injectors and fuel management otherwise you will run very lean.
