Comptech Fpr question
Old May 27, 2010 | 12:57 PM
s2konroids's Avatar
Default Comptech Fpr question
Hi just a quick one, i have a fuel pressure gauge on the fuel rail from the Fpr.
With the car idling with handbrake on in neutral...
If i rev the car 'slightly' manually via the throttle body butterfly to ~3k rpm should the fuel pressure rise quickly then drop down to its set pressure ie move the TB butterfly then let go.
I thought they weren't supposed to move? - my gut feeling is it should as I'm letting air in when opening the TB plate. At the moment is jumps up slightly then if i let go it drops back down again, its just a read the FPR is 'static'.
Thanks
Old May 27, 2010 | 10:33 PM
s2konroids's Avatar
Bump
Old May 28, 2010 | 02:47 AM
SRap1's Avatar
yes, mine does the same
Old May 28, 2010 | 07:46 AM
s2konroids's Avatar
Thanks
Silver S2k4
May 7, 2007 11:50 PM
