Comptech fuel pressure regulator V's
Old Oct 16, 2005 | 07:56 AM
markS2kcU's Avatar
Default Comptech fuel pressure regulator V's
Can you use the AEM regulator that sits on the fuel rail instead of using the Comptech regulator?
Which would you say was the better one and why?
Old Oct 16, 2005 | 08:15 AM
Sideways's Avatar
What have you done to your car?
Old Oct 16, 2005 | 08:49 AM
markS2kcU's Avatar
Nothing yet
I'm getting ready for more boost, got the EMS and tuner sorted, getting bigger injectors and then I read it might be helpful to use the AEM fuel pressure regulator.
It will be alright to use it now running stock set up?
Old Oct 16, 2005 | 01:27 PM
folex187's Avatar
The AEM doesn't rise the fuel pressure as much as the comptech.
Old Oct 16, 2005 | 01:49 PM
AusS2000's Avatar
They are two different things. If you're using the standard Comptech tuning you need the Comptech FPR (high ratio). If you're using proper engine management and larger injectors then you can use a conventional FPR (1:1 ratio) like the AEM.
I use the AEM EMS, 550cc injectors and the AEM FPR.
Old Oct 16, 2005 | 02:29 PM
markS2kcU's Avatar
I wish I had posted this last night, then I wouldn't have fitted it yet.
A/F ratios were shocking with the AEM fitted.
Guess what I'm refitting tomorrow.
Cheers guys.
Old Oct 16, 2005 | 02:46 PM
Slows2k's Avatar
You can't swap the Comptech FMU to a 1:1 FPR without having some other means to add fuel in boost.
Old Oct 16, 2005 | 05:08 PM
folex187's Avatar
Anyone successfully used an AEM with stock injectors and emanage or aem ems?
Old Oct 16, 2005 | 05:17 PM
Sideways's Avatar
Yes.
duff0000
Apr 24, 2008 07:04 PM
2QYK4U
Jun 17, 2007 07:27 AM
Headchef
May 16, 2007 03:00 PM
pushin9
Nov 9, 2006 06:03 PM
Liemoanh
Apr 24, 2005 09:56 AM
