Comptech Novi Oil return line
Old Jan 28, 2011 | 01:17 PM
s2konroids's Avatar
Default Comptech Novi Oil return line
So after a successful SC Novi 1000 rebuild i thought my car was running sweet as a nut, unfortunately upon removal i knicked the braided oil return line (broke a few strands) on the cross-member, or i pulled the tubing out slightly.
I thought it would okay as i blew air through it and no air leaked, however oil is a funny thing and it leaks now .
I must be under very low pressure as it just leaves a 2"x2" small oil puddle on the drive when HOT - i have been monitoring it and it doesn't seem to leak that much from the dipstick.
For me i really cant be bothered taking off the supercharger yet again but...
1. Can i remove the oil return line without removing the supercharger?, as we all know there is hardly any room to manoeuvre about underneath the supercharger. Perhaps i could modify a spanner to stop fouling the SC housing?
2. Maybe its just come loose at the top, anyway i can push it up and re-tighten, how would i go about doing this?
3. Are the CT oil return lines rubber tubing inside the braided line?
4. If its pierced in some way on the rubber tubing, can I melt it and let it dry and reseal the hole? - seems an odd idea but I've seen this technique used before.
Thanks
Old Jan 28, 2011 | 01:39 PM
goldenfri's Avatar
I can't imagine you can replace that line without pulling the supercharger again, there just isn't enough room to work.
Old Jan 28, 2011 | 01:49 PM
s2kadrenalin's Avatar
If you get the car on a hoist, you can tighten / undo the fittings to the sump / S/c much easier.
Also, if it is tight, but still leaks around the fittings, you can use "thread tape". I did this when I cross threaded my oil nippler until my new one arrived. Worked a charm.
Failing that, contact CT-Engineering and order a new braided hose line / fittings. Will probably cost you $200-$300 but for piece of mind you'll have the right part that fits properly.
Old Jan 28, 2011 | 01:51 PM
s2konroids's Avatar
Shiiit
It was a pain in the arse removing it last time, my back ached for days and I'll have to do it again.
Old Jan 28, 2011 | 02:00 PM
Trust me, get it on a hoist, makes life so much easier.
Alternatively, unbolt the S/c from the brackets (along with the aftercooler).
I left that bottom **** of a bolt threaded in, however you can twist the S/c & backing plate vertically up. This gives about 123489% easier tightening / loosening to the braided hose at teh base of the S/c. Downside is, putting it all back together for the next 45 minutes or so.
Old Jan 28, 2011 | 02:02 PM
Undo the bracket bolts, and twist vertically.
Old Jan 28, 2011 | 02:05 PM
s2konroids's Avatar
thanks
Old Jan 29, 2011 | 02:01 PM
s2konroids's Avatar
Can anyone tell me the spec of the line and connectors?
Is it an -8AN?
Thanks
Old Jan 30, 2011 | 01:34 PM
s2konroids's Avatar
anyone?
Old Feb 5, 2011 | 01:39 PM
s2konroids's Avatar
Sorted you don't need to remove the SC, you can take a little off the head of the spanner so it doesn't foul the SC housing. I just replaced the whole line and reused the connectors. It had perished overtime so i didn't really damage it . Bit of a PITA due to the braids which can split and come loose, thus work its way out.
For future reference it is -8AN, the standard line is 15" but i recommend 17" as it doesn't touch the sump any-more and has a little more slack.
