comptech pulley alignment
Old Oct 23, 2013 | 04:12 PM
s2kbtos's Avatar
Default comptech pulley alignment
Is there anything that is missing that is not helping the pulley align?
Old Oct 23, 2013 | 04:49 PM
s2000Junky's Avatar
Yes, the problem is your tentioner bracket/pulley is mounted to the wrong side, it should be mounted to the outside(face)of the blower face plate.
Old Oct 23, 2013 | 08:15 PM
s2kbtos's Avatar
I have changed the position of the bracket and it still not aligning ....
Old Oct 23, 2013 | 08:20 PM
s2000Junky's Avatar
Your SC pulley is also on backwards. Flip it around.
Old Oct 23, 2013 | 08:30 PM
s2kbtos's Avatar
when it was the other way it would get stuck with the bracket...and i showed the guy from comptech the picture and told me it was backwards and now it is swtiched......
Old Oct 23, 2013 | 09:04 PM
spap1's Avatar
looks like the tensioner is now correct but the pulley does look flipped. idk hard to see in the pictures but mine sits VERY close to the blower housing itself, and is flat on the blower side and stepped on the backside with the bolt
Old Oct 23, 2013 | 09:11 PM
s2kbtos's Avatar
its weird because this way i'm able to use a pulley tool, but the other way around i can't use atool i had to have someone pry it out...
Old Oct 23, 2013 | 09:22 PM
s2k manic's Avatar
sc pulley upside down and possibly missing large washer that goes under the pulley here is a pic Chris at ct engineering sent me hope this helps call them and they can email all the info you need
Old Oct 24, 2013 | 09:02 AM
s2000Junky's Avatar
You might be missing the large comptech washer that goes behind the pulley to stand it off slightly. It is currently on backwards though.
I lost mine at one point when the pulle came off on me, I managed to find a washer that fit close eough to work. It needs to be about 1/8" thick and fit over the 7/8" shaft of the blower.
Old Oct 24, 2013 | 09:08 AM
s2000Junky's Avatar
Typically you do have to give them a bit of a pry, not uncommon at all.
