comptech question?
Old Jan 14, 2009 | 08:54 AM
FSTS2K's Avatar
Default comptech question?
i'm getting the ap2 comptech supercharger kit but i want to know if i'm going to have trouble intalling it on my 02 ap1..
thanks guys
Old Jan 14, 2009 | 11:50 AM
tbtak's Avatar
Try this and ask..
ttp://www.comptechusa.com/
Old Jan 15, 2009 | 04:45 PM
s2k aok's Avatar
i have a 2002 ap1, no difficulties at all. i tried to custom fit the air box but after two days of trying to fit it i gave up. the air box isn't necessary though. i have a used old comptech non-ac kit with the pre-esm kit that used a check valve. if you do get a kit with the esm i'd just get the "missing link" by synapse (i got mine through nipponpower.com in miami) it was very cheap i want to say $50 or so versus $150 for an esm. all you do is install it between the map sensor and the throttle body and that's it. the hardest part i had was removing the crank pulley. some say the fuel pump is hard but it was easy for me. i did the install 100% myself.
Old Jan 15, 2009 | 09:10 PM
nightcrawler7188's Avatar
you won't have any problems
Old Jan 16, 2009 | 07:16 AM
FSTS2K's Avatar
thanks for the info guys
Old Jan 16, 2009 | 07:27 AM
pdexta's Avatar
Make sure you check the air fuel ratios once the kit is installed. With an AP2 kit on an AP1 you'll be running a little more boost than the kit is intended to run, since the AP2 pulley is a bit smaller (it'll be like 6psi instead of 5psi). You'll need to adjust the fuel pressure regulator to give you a little more gas or the car will run lean.
I've got an extra stock AP1 pulley. If you'll send $10 to cover shipping I can send it to you if you want to run stock boost.
Old Jan 16, 2009 | 10:45 AM
you might as well run the AP2 pulley on the AP1, it'll give you the max boost you can run without having to get injectors or real engine management.
Old Jan 16, 2009 | 02:58 PM
sabelotodo's Avatar
kj has some custom pulleys and maps on his aem computer. LET ME DRIVE IT! ahaha DUDE let me know if you need help with the install me n my subie friends are down we have worked on kjs car so yah
Old Jan 16, 2009 | 03:00 PM
sabelotodo's Avatar
and then in a year when i graduate you can sell it to ME!
Old Jan 16, 2009 | 03:53 PM
pdexta's Avatar
Well that's fine, and that's what I did w/ my car when I had it, but you HAVE to adjust the FPR for the smaller pulley or you'll be slinging oil and pistons all over the road. That's all I was saying.
