comptech SC with AC HELP!
Old Mar 30, 2007 | 07:22 AM
ronaldng0809's Avatar
Default comptech SC with AC HELP!
hello, i just bought a used comptech sc with AC kit from one of the member here. the problems is he didnt send me all the parts from the kits because his local shop didnt take out all the parts from his car.
here is the missing parts from the kit
ESM
Fuel pump
Fuel pressure regularor
Oil pan fitting
Mounting washer parts ( 4 metals and 2 rubber)
i think those parts are still in his car, but my question is can i used the aftermarket parts instead of comptech. is it gonna work. For example can i use the other brand Fuel pump........ and also some of the washer from the kit is missing. can i still be able to mount it on my car without problems?? Thanks for your help.
Old Mar 30, 2007 | 09:51 AM
raymo19's Avatar
I don't think Comptech manufactured much if any of the kit. The fuel pump is a Walbro for example. I'm unsure as to the other parts you're missing.
Old Mar 30, 2007 | 10:12 AM
suprfunguy's Avatar
ESM
Fuel pump
Oil pan fitting
You may have a tough time getting your hands on a Comptech ESM. However, I think one is still for sale in the "For Sale" forum. You should be able to obtain all the other parts from other sources.
If I were you, I'd check with "Hardtopguy". He may have some extra Comptech parts laying around
Old Mar 30, 2007 | 10:15 AM
73Zero's Avatar
ESM - Basically, this is a "voltage clamp" for the MAP sensor. You can try one of these: http://www.splitsec.com/products/clamps.htm
Fuel pump - This is an off the shelf Walbro 255lph in-tank fuel pump.
Fuel pressure regulator - Somebody once identified who manufactured this part for Comptech, but I can't seem to find that link. Well, it's basically a rising rate FPR, like this one: http://www.racetep.com/begireg.html
Oil pan fitting - According to the instruction manual, this fitting is a [B]14mm to
Old Mar 30, 2007 | 10:23 AM
thanks guys, those information are really helpful.
Old Mar 30, 2007 | 10:48 AM
John_Z's Avatar
Let me know if you need a rising rate fpr. I have a Vortech unit avail.
Old Mar 30, 2007 | 07:04 PM
ATOice's Avatar
I have the comptech fpr if you need, shoot me a pm. Fuel pump is like 73zero said, you can find that on ebay.
Old Apr 4, 2007 | 09:54 AM
Kyushin's Avatar
Banned
For the oil pan fitting, I saw sooo many and none matched the sizing you described.
scorchza
16
Jun 22, 2009 07:18 AM
jmrobins
15
Sep 16, 2004 05:59 PM
LVGPWhite
Feb 16, 2004 03:26 PM
