Comptech sc with aftercooler installed
Old May 3, 2006 | 08:11 PM
Titounais's Avatar
Default Comptech sc with aftercooler installed
The car is not really faster. I mean, under 6000 rpm it's even worst than before. After 6000 rpm I can feel a medium kick but not wheelspin, even on wet surface on first gear.... My only hope to fix this lack of performance is to install my Electronic Signal Modifier. Do you guys think that's gonna make a huge difference on my problem of lack of performance? I have everything else installed ( FPR, the compressor, the aftercooler... The fuel pump.) Someone can tell me if it's only as weak until I install my ESM? The fuel pump is a Walbro 255Liter per hour. The installation have been done by a mechanic.
Old May 3, 2006 | 08:41 PM
SilverKnight's Avatar
who did your install? For low RPMS I go thte gears
Old May 3, 2006 | 08:45 PM
xviper's Avatar
You're kidding, right? Why would you even drive the car without the ESM. The ECU cannot see boost.
Old May 3, 2006 | 08:48 PM
Titounais's Avatar
xviper, It was for a test drive to make sure that everything is okay. The performance concern comes after (and that's why I am posting this) since I am waiting for the ESM to finalize my setup. I just wanted to be sure that the lack of performance is due to the EMS thing. Can someone tell me?
Old May 3, 2006 | 08:49 PM
Titounais's Avatar
Btw, Calgary Flames lost the series
Old May 3, 2006 | 09:02 PM
ESM? this comes with the comptech kit right? I'm confused If it doesnt then you need an ESM to install this?I thought this was a bolt on kit
Old May 3, 2006 | 09:05 PM
Titounais's Avatar
Esm comes with the package, but I bought it used, so... it didn't came with and I am not really patient with that situation.
Old May 3, 2006 | 09:10 PM
ok whew
Old May 3, 2006 | 09:16 PM
D-S2K's Avatar
so you bought the kit used, that made more sense now.
to answer your question, yes the esm is important to the SC set up. like Xviper said, the stock ecu cannot see boost, and your car will not run well without it. i'd strongly suggest you install the esm asap.
Old May 4, 2006 | 05:45 AM
00S2K01S4's Avatar
ESM hides boost. Without it the ECU will retard timing hence the lack of power.
