Comptech SC strange sound!HELP!
Old May 6, 2005 | 07:34 PM
yy22's Avatar
Default Comptech SC strange sound!HELP!
just get my Comptech SC and AC kit on my MY04 S. when i open the hood, i very big sound when i just strart the engine(about 1000RPM). it sounds like a OLD BIG TRUCK!!! i also can hear something sounds like a air-plane engine. i do hear those two kinds of sound and i really feel strange. is that normal? or something wrong with the kit? does anyone have the same experience? i really need your help!!!!
thank u very much!!!!
Old May 6, 2005 | 08:14 PM
xviper's Avatar
This doesn't tell us much. I've heard a few OLD BIG TRUCKS in my day. They all sound different. Same goes for an airplane engine - Radial? Twin? Flat 4? Turboprop? Jet? Merlin? What?
Anyone else want to tackle this? "Noise" questions! Gotta love 'em.
Old May 7, 2005 | 07:27 AM
Liemoanh's Avatar
The OLD BIG TRUCK might be the supercharger itself. Upon start up, the supercharger experiences gear back lash for roughly 10-30 seconds, then settles down to a more "marbles in a can" type noise. This is typical for Comptech superchargers.
The AIRPLANE noise might be the air pump pumping in air to accelerate the emissions process to warm up the catalyc converter, thus causing less pollution in the air.
Please correct me if I'm wrong.
Old May 7, 2005 | 01:46 PM
modifry's Avatar
Honorary Member
It's normal to make "lots of noise" compared to the stock engine, but it's hard to judge over the Internet. If it runs OK and there's no vibration it's probably fine.
There will be the noise from the internal gears - makes rattling sounds at idle, almost as if there's something loose in there. From inside the car it sounds a little like a diesel knock going on. When you drive the car under load almost all of this goes away or is masked by other engine/air noises.
Then there is the "air" sound that will vary with rpm and whether you've got the stock air filter or done something different. Mine is loudest at 2900rpm with the standard Comptech intake, not a problem since most driving is above that.
XV - We (you) should get a copy of Honda's explanation of car noises. I've seen it posted at my local dealer. It has excellent descriptions of about 40 different noises and would be a great reference to have here so members can refer to it and decide if their noise is a "grind" or a "groan" or a "bump" or a "thump". If you can't find it I'll go make a copy and try to OCR it.
The air pump referred to by Liemoanh only runs for like 60-90 seconds when the car is first started, and only if the engine is cold. I've never heard mine run, but then I haven't listened for it.
Old May 7, 2005 | 02:53 PM
xviper's Avatar
I've never seen this. It would be interesting to have this posted up. If you can post this up in a thread in UTH, I'll link it to the FAQ thread.
Old May 8, 2005 | 10:23 PM
BroInTheKnow's Avatar
Banned
did u test drive the car yet?
Old May 10, 2005 | 10:24 PM
watchyosix's Avatar
Maybe you live next to an airport encompassed by a few highways? I'm not much of an expert but I remember that I always use to hear a hissing sound everytime I would start my car. I figured it to be a normal mechanism. I never did hear about that "noise" guide Honda published.
Old May 17, 2005 | 02:06 PM
Silver S2k4's Avatar
My car makes all kinds of noises. I also have an 04 with the comptech kit with AC and just installed the Godzilla BOV. My friend drove with me the other day and he said that he doesn't know which noise does what because there are so many. SC whine, BOV letting out air, the grind at idle, the sucking of the intake......and it does resemble a jet engine at idle.
Old May 17, 2005 | 04:43 PM
OyATL's Avatar
I love the sound of my Comptech!
Old May 17, 2005 | 08:50 PM
SIIK2NR's Avatar
Damn........can you still hear your music? or is it THAT loud...??
