COMPTECH SUPERCHARGER
Old Nov 21, 2007 | 07:10 AM
sruajax's Avatar
Default COMPTECH SUPERCHARGER
MY FRIEND HAS A COMPTECH SUPERCHARGED S2000 AND WANTS IT BACK TO STOCK.
WHAT PARTS DO I NEED TO MAKE MY FRIENDS S2000 BACK TO STOCK THE ONLY THING HE HAS IS THE SOCK INTAKE BOX? THANKS IN ADVANCE
Old Nov 21, 2007 | 08:15 AM
jwa4378's Avatar
Remove EMS, remove the blower, replace the comptech crank pulley w/OEM one, technically the fuel pump should also be replaced, but its not required. It really depends on the setup. Not a lot of OEM parts should have been removed/replaced other than the airbox and the fuel pump... just more stuff added.
It is really dependent on whether he has larger injectors or if he is running an FPR vs. full EMS. Need more details about the setup other than its a comptech...
John
Old Nov 21, 2007 | 08:20 AM
manuelisfun's Avatar
I'll take it off his hands, for FREE!
Old Nov 21, 2007 | 11:29 AM
sruajax's Avatar
STOCK INJECTORS HE JUST HAD THE SUPERCHARGER ISTALLED AS IT CAM IN THE BOX. HOW SHOULD IT TAKE TO REMOVE?
Old Nov 21, 2007 | 12:43 PM
CourageOO7's Avatar
WTF IS WITH THE CAPS?
Old Nov 21, 2007 | 12:52 PM
sruajax's Avatar
IM AT WORK A WE USE CAPS FOR EVERYTHING
Old Nov 21, 2007 | 01:40 PM
Slows2k's Avatar
Turn the caps off for S2Ki
Old Nov 21, 2007 | 02:04 PM
TRBOKEV's Avatar
Its really easy to remove and can be done in around 3-4 hours total time.
Old Nov 21, 2007 | 04:32 PM
jwa4378's Avatar
Out of the box doesn't tell anything... is it tuned with the ESM and the FPR? or did he use something like AEM.
Personally, if you cannot identify what was installed, you should not be doing the uninstall. Also, I believe there are instructions provided by Comptech on step by step how to install the kit. Just run in reverse.
If its tuned with the FPR, just the ESM, FPR, remove the compressor + piping, replace the crank pulley, and fuel pump (if it was replaced to begin with with a Walbro) and I think you should be good to go (assuming nothing else was used to tune the kit).
Let me know if I missed anything... never had the kit, just remembering what all goes into it...
John
Old Nov 21, 2007 | 08:36 PM
SIIK2NR's Avatar
Replace with stock fuel pump
Replace with stock air box
Remove FPR
Replace with stock crank pulley or just remove the Blower pulley from the crank pulley
Remove ESM and reattach wires
Reattach vacuum lines
If all else fails, download the install instructions and follow the steps backwards.
kerm1t
Nov 24, 2012 09:04 AM
kylemonster85
Jun 11, 2010 03:25 PM
SWIFT2000
Sep 18, 2007 10:02 AM
superslows2k
16
Sep 26, 2006 01:54 PM
bumpins2k
Aug 19, 2005 10:33 AM
