Comptech supercharger help
Recently picked up a used very incomplete comptech sc kit .. good mechanical condition. no noises when spinning the turbine. no vibrations nothing is loose
here is a picture
Is there installation instructions online somewhere.. and a parts list for the comptech like detailed down to every little bolt and washer you should have?
Can anyone tell me what im missing?
here is a picture
I was told I didnt need an FMU with my AEM EMS. But I dont know if that is the same as a FPR. You wont need the Injectors unless you plan to go above 8lbs of boost per my tuner. I cant see the pics since I am on a military computer. But there has to be a pic online to check against what a out of the box comes with. Or a list of parts. Check out Comptech.com or PTuning.com.
well i have the science of speed pulley on there 3.8'' for 2.0l which should make at least 8psi if not 9.. and it will most likely be aftercooled... i guess if i dont buy the aftercooler system the psi would drop to about 7.5ish and i can get away without useing aftermarket injectors but i want to be well over 300whp ... looking for more like 350+
The other lists of mods are
Bored out intake manifold (already have)
SOS 70mm TB (WTB)
Greddy Ti-C (WTB)
Berk Header (WTB)
Any 70mm TP (WTB)
550cc or 650 cc or 675cc Injectors (WTB)
SOS 70mm TB (WTB)
Greddy Ti-C (WTB)
Berk Header (WTB)
Any 70mm TP (WTB)
If your going with a smaller pulley you will need engine management as well as a clutch.
I am sure on comptechs site you can find a parts list.
I am in a similar situation with a Vortech kit and on their site they have a parts list. Still hard to figure out what I need but I do have a list and install manual.
Looks like you have none of the hardware so will be needing all of that for sure as well.
this is the closest thing i can find to a complete kit checklist... a small picture..
i need part numbers and a way to order what i need... im really not worried about cost as long as its cheaper to do it this way as opposed to buying an entire kit new =(
I have a paper copy somewhere. Give me a day and I'll find it...just gotta figure out how to get it on here. I haven't scanned anything in years! Worst case, I'll snap a photo and post it.
CT engineering will still sell you most any part. I emailed them a while back when I had the blower off thinking I would be anal and replace the rubber damping bushings. They were $25 each! I think there are 8.....um, no thanks. Other stuff like the couplers were reasonable. Clamps and hoses you can get anywhere.
