comptech supercharger oil line
You can buy them from Comptech or SOS individually, or you can buy them from Summit. See this thread for details and part numbers:
https://www.s2ki.com/s2000/topic/957...o-the-oil-pan/
I bumped it to the front page for you.
there is a hose coming from the supercharger... where does that connect ? if i get get the parts listed above what kind of hose and how big do i need it to be to get the oil back to the supercharger?
That's the oil return. Goes where your oil drain plug is . Take you oil drain plug out and put in the fitting and connect the oil drain hose to it.
Other oil line is the oil feed line . Probably -3an line. Goes from sc to v tec solonoid spacer.
is that hose that shows on the picture from the supercharger be long enough to connect to the oil pan, or do i need to buy an extension?
That is it...the line goes to the blower, there is a fitting on top of the blower that the 90 degree end of the line goes to. Your vtec solenoid will bolt to the outside of the purple bracket with the long 10mm bolts.
