Comptech Supercharger problem
Old Jun 2, 2007 | 09:09 AM
gots2000's Avatar
Default Comptech Supercharger problem
I bought a used comptech supercharger with aftercooler about a month ago. I installed it and have about 100 miles on it since i installed it. I took a cruise this morning and the car started to stall when i hit the gas. I got up to about 5000 rpm when it started to do it. I parked it right away and let it sit for about a half hour. I again tried starting it and started to stall right away without even pushing on the gas. Im thinking its the spark plugs since im still running the stock ones but im not sure. Any suggestions anyone?
Old Jun 2, 2007 | 09:19 AM
AirborneS2K's Avatar
what psi belt/pulley?
Old Jun 2, 2007 | 09:22 AM
gots2000's Avatar
I got a stock comptech pulley and a gator belt on it.
Old Jun 2, 2007 | 09:28 AM
elusiv's Avatar
check your belt, soldered connections, oil level and spark plugs.
running stock ones are ok FYI.
Old Jun 2, 2007 | 11:46 AM
gots2000's Avatar
The belt is fine,connections are fine,the oil level is right up to the top line,and i replaced the spark plugs and the car is still stalling.
Old Jun 2, 2007 | 01:24 PM
CKit's Avatar
Are you tuned?
Take a picture of your FPR (fuel pressure regulator). It's the red thing. You may be running rich and fouling your plugs.
Especially if the previous owner was running a slightly different psi or plugs.
Old Jun 2, 2007 | 01:47 PM
gots2000's Avatar
Here the fuel pressure regulator:
Old Jun 2, 2007 | 03:54 PM
CKit's Avatar
DAMN!!! That screw is backed out a LOT. If you screw it down (allen wrench) it richens things up. It depends on whether that's the stock screw (because there are different FPR screw options).
I'd check your spark plugs to see if they're white or black. It'll tell you if you're running lean or rich.
I'd recommend changing your plugs anyway (NGK coppers $1.50 each, only takes 15 minutes with standard hand tools).
Then going to get it tuned before something bad happens.
I'd consider screwing that allen bolt in almost all the way down, then pulling the ECU fuse to reset it in the meantime.
Old Jun 2, 2007 | 04:30 PM
gots2000's Avatar
The stock plugs where white which is running to lean correct? Well, ill screw the bolt all the way down and then pull the ecu fuse to reset it.
Old Jun 2, 2007 | 05:27 PM
Spec_Ops2087's Avatar
Personally, I wouldn't touch anything without an A/F gauge of some kind (a dyno will be best).
You might have an aftermarket screw in there and by screwing it down all the way, you might flood your engine with fuel.
