Comptech and Synapse Syncronic BOV Install Question
Old Mar 15, 2012 | 10:38 AM
jsenclosure's Avatar
Default Comptech and Synapse Syncronic BOV Install Question
So i got a Synapse syncronic BOV for my Comptech S2000. Now i know i need to weld on the flange to the aftercooler which is no big deal, then i'll plug off the hose connection that goes into the intake tube which is also easy enough.
Now here is where i get lost, there are two small fittings that come off the bottom of the BOV that should get tied together with hose (like a Y) and then the hose would run to the bypass valve hose (that is on the intake manifold) for the secondary air injection system. My secondary air injection system has been removed and i have the izze-engineering kit. So where would this hose tie into?
Thanks
Old Mar 15, 2012 | 02:18 PM
Ive been thinking about this. I think I just run it to my intake manifold to where I have the port capped off for the air pump delete. Sound about right?
Old Mar 15, 2012 | 03:01 PM
DFWs2k's Avatar
Yes, you are so smart.
Sent using free Tapatalk - Android FTW
Old Mar 16, 2012 | 05:35 AM
Do i still need to install the plastic check valve that would normally be inline with the secondary air injection system on this small hose line?
Old Mar 17, 2012 | 06:36 AM
Anyone?
Old Mar 19, 2012 | 02:14 AM
Bump for an anawer
Old Mar 19, 2012 | 06:16 AM
macdaddies911's Avatar
I'd like to hear this too.
Old Mar 21, 2012 | 11:25 AM
bump for an answer
Old Mar 22, 2012 | 08:00 AM
bump for an answer
Old Mar 22, 2012 | 11:31 AM
finally found a couple pictures and i think i know what's going on now. Hose connection goes from the bov to the intake manifold where the air pump associated hose would normally go, no check valve needed
