Comptech with or without aftercooler?
Old Feb 28, 2007 | 12:51 PM
RED MX5's Avatar
No tuning is required (or needed) with a stock CTSC (or VTSC), with or without AC.
However, getting a CTSC is apt to be a problem, because as has already been pointed out, Comptech has gone out of business. If you want a no-tuning-required CARB legal FI setup, Vortech is now the only choice.
Old Feb 28, 2007 | 02:11 PM
raymo19's Avatar
The only caution I would add to this is if you've made exhaust modifications you may want to dyno tune the car to make sure you're not running too lean.
Old Feb 28, 2007 | 03:02 PM
Ustemuf's Avatar
my AC has a lil leak in it so if i don't refill it up, it gets super hot. i can tell when it needs refilling because i can tell there is a power loss from the heat soak.
now you can imagine if you didnt even have it ...hope that answers your question.
Old Feb 28, 2007 | 04:51 PM
RED MX5's Avatar
Any engine mods in addition to the SC can throw the tuning off. It also never hurts to put the car on a dnyo or install a wideband AF logger (or gauge) so you and see what the AF looks like, even if you don't need to tune.
Old Feb 28, 2007 | 05:01 PM
Ustemuf's Avatar
i have stock cat + stock exhaust and even with the pressure turned up as much as possible i'm still running lean in the 6-7K RPM range. everything other than that is good. lots of people with comptech kits are lean in this area.
if you add a test pipe and a high flowing exhaust you will definately lean out to dangerous conditions.
Old Feb 28, 2007 | 06:25 PM
TRBOKEV's Avatar
I use to get what I thought was heat soak untill I got my car tuned. Now it no longer does that... I know now that I was running pretty lean when this was happening.
(and I'm non aftercooled)
Old Mar 1, 2007 | 01:30 PM
RED MX5's Avatar
MY02-03 cars run a little leaner than MY00-01 cars, but I still don't think you should have to crank the FPR all the way down. No other mods? Correct fuel pressure off boost?
mknightx
Aug 21, 2006 10:12 AM
babbagandu1
Apr 15, 2006 08:09 AM
Sub-Zero
Jan 5, 2005 12:41 PM
JAYZS2000
Apr 6, 2004 06:11 PM
