Computech SC + stock injectors+VAFC2, help
Old Feb 2, 2010 | 01:08 PM
s2konroids's Avatar
Default Computech SC + stock injectors+VAFC2, help
I apologise for asking but I'm getting bombarded with info and getting confused in the process plus the search is down
I read you cant run too much boost with stock on injectors on a vortech SC, i was planning 8-9psi.
I just want a basic setup so i DONT want to upgrade the injectors or a standalone ECU.
I was planning on gettting a 2nd hand vortech SC, but i fear i might have to ditch my tracysports header and t1r v2 63 unless i upgrade the injectors?
As I have a VAFC2 which i believe would work okay with the FPR??? would i likely get gains - I know the VAFC2 is quite limited but at least i could lower vtec and run better safer AFR's.
^ I presume only if ran stock exhaust+stock manifold and a testpipe, not my ts header+t1r?
Lastly what BHP would the setup but good for at the crank?
Thanks in advance.
Old Feb 2, 2010 | 01:54 PM
Little_AP1_S2K's Avatar
your stock injectors will max out with a AEM FPR at around 8 psi. alot of people say 7psi but you will not go any more then 8 for sure. vafc will tune good enough for that low of boost just use it to trim the fuel. GL
Old Feb 2, 2010 | 02:03 PM
s2konroids's Avatar
Your kit your selling comes with a 9psi pulley though? so no good on stock injectors?
thanks
Old Feb 2, 2010 | 03:03 PM
are you a ap1 or ap2? becasue it depends on your redline to see what it goes to the 3.6 pully is 9psi on a AP1 not sure on a ap2 it will be alittle lower. like umm 7-8 psi not sure i can look into it for you. also the ap1 stock pully is 7 psi
Old Feb 2, 2010 | 11:20 PM
s2konroids's Avatar
I am AP1, i think it maybe not good on stock injectors?
Old Feb 3, 2010 | 03:54 AM
you could run stock pully to get 7 psi and you would be fine but jumping to the 9 psi one would not be so good.
Gyroscope
Dec 15, 2009 06:07 AM
dragtek
May 24, 2007 12:04 PM
nichigo
May 7, 2007 11:38 AM
Zonie
Feb 27, 2004 02:14 PM
JohnChan
Nov 30, 2003 04:05 AM
