Confused about SC
Old Aug 15, 2007 | 10:46 AM
S2-3456789-K's Avatar
wow, this is very interesting. didn't know there are root type sc kits made for the s2k. the dyno also looks like something i'm looking for. looks like your setup holds ~90% max torque for around 5000 rpm, which is very impressive, and 300 whp is definitely plenty for me.
can you comment on the reliablity of your setup? what about maintainence? Thanks!
Old Aug 15, 2007 | 11:44 AM
WLAURENT's Avatar
I have over 15k miles on it so far and it is tuned using an emanage ultimate - Drivability is excellent, with OEM like throttle response, etc.. Feels like you are driving a V6 or V8 S2000.
I actually drove the car from Phoenix to South Carolina (for the WTD meet) about 2 weeks after the install - 5200 miles in 7 days.
The car will be at the 8 Sept. Homecoming Meet in SoCal if you were going to be there and wanted to check it out.
Old Aug 15, 2007 | 12:11 PM
Originally Posted by WLAURENT,Aug 15 2007, 10:24 AM
Using some type of blow-off or pressure relief valve may work - but it would be very difficult to keep repeatable.
why do you suppose it would be difficult to design pressure relief for a SC? if a turbo wastegate can relieve exhaust pressure from over-spinning a turbo, it would make sense that a similar "thing," for a lack of a better word, can be designed to relieve intake pressure, wouldn't it?
i guess if this is accomplished with a BOV, it would be annoying to have that "pshhhhht" sound from say 7k-9k rpm, but a quiet sprung gate design seems reasonable. but then you wouldn't be able to have a BOV sound when you want it. doh.
btw, your setup does sound very reliable, and i love the torque curve!
Old Aug 15, 2007 | 05:32 PM
BondoBuilder's Avatar
Originally Posted by S2-3456789-K,Aug 9 2007, 05:45 PM
1) i've seen that in a lot of threads, people upgrade to a smaller pulley for more boost. this makes sense because you increase your crank/pulley ratio to allow for high max pulley speed. however, wouldn't it bog you in the low RPM range? i guess it's like starting in 3rd gear instead of 1st? to me it seems that a smaller pulley would hurt low (and perhaps mid) range throttle response, as more engine torque is required to accelerate the smaller pulley. i guess my real question is...is there an "optimum" pulley size for the street, where mid-range and trottle response is more important (to me at least) than max boost?
I have a Comptech AC SC system. I modified my kit using an ASPRacing 4.2" pulley (8#). I have never noticed any bog. The forced induction does not begin until VTEC, or just prior to it (centrifugal SC). It's like VTEC on steroids!!
Old Aug 17, 2007 | 04:14 AM
CKit's Avatar
Not quite right. FI starts right away, but like people have said, the curves don't separate very much until VTEC crossover.
Old Aug 17, 2007 | 04:16 AM
CKit's Avatar
That is a NICE torque curve. If I had more city driving and hadn't gone CTSC, roots would be a nice solution.
Anyone else driving a roots blower?
Old Aug 25, 2007 | 10:19 PM
quick question: i know in turbo cars if you're easy on gas, you can drive around and not build boost (until you're really high up in RPM), but is that possible with superchargers?? it's belt driven, so does RPM dictate boost regardless of trottle position? thanks!
Old Aug 26, 2007 | 02:50 AM
freshs2k's Avatar
You can drive around without being in boost in a cetrifugal your recirculationg bypass valve leaks the boost if your not WOT. Plus its rpm dependant so you won't make boost untill 4-5k.
Old Aug 26, 2007 | 08:05 AM
HMFIC's Avatar
so below 4-5k, your not boosting? even at WOT? so its like driving a stock S2000 until you hit 4k? i'm confused. I thought it was like driving a v8 or something.
Old Aug 26, 2007 | 09:27 AM
freshs2k's Avatar
a comptech is centrifugal its rpm dependant I'm only doing 5 psi at 8k. If I pushed 10 psi I'd get boost sooner in the rpm band because of the smaller diameter pulley it would spin the charger faster and make boost sooner. Driving around in my sc'er I don't get boost all the time only when I'm above 4-5k WOT even then its only 1 psi. My bov leaks all the excess air when my throttle plate is closed. Its like driving a stock s2000 around the city then hit vtec and that's when the sc'er comes into play.
