Converting to fuel return
Old Mar 14, 2016 | 10:01 AM
Rays S2k's Avatar
Default Converting to fuel return
Planning on boosting my06 within the next month I already ordered a fuel return kit now my question is can i install it and be fine or will I need to do something with the stock tune
Old Mar 14, 2016 | 10:28 AM
King Tut's Avatar
Stock tune should be fine as long as you run the same fuel pressure on the regulator.
Old Mar 14, 2016 | 10:31 AM
Rays S2k's Avatar
OK awesome do you happen to know what the stock fuel pressure is
Old Mar 14, 2016 | 10:34 AM
King Tut's Avatar
I wanna say it is 63.5 psi according to Hondata, but I will have to check my tune file when I get home to verify.
Old Mar 14, 2016 | 10:37 AM
Rays S2k's Avatar
Originally Posted by Rays S2k' timestamp='1457980297' post='23908147
[quote name='King Tut' timestamp='1457980110' post='23908142']
[/quote]
OK awesome please let me know thanks.
Old Mar 14, 2016 | 06:36 PM
TUKES2k's Avatar
pretty sure its 43.5... are you changing the pump and injectors?
Old Mar 15, 2016 | 04:11 AM
Rays S2k's Avatar
[/quote]
Yes I'm doing fuel pump once I install the turbo then I'll install the injectors
Old Mar 15, 2016 | 05:17 AM
TUKES2k's Avatar
Gotcha... so you pretty much just wanna install the fuel lines and regulator
Old Mar 15, 2016 | 05:20 AM
liquidgsr's Avatar
What kit did you go with?
Old Mar 15, 2016 | 05:21 AM
Rays S2k's Avatar
I went with pfab stage 2
