Converting to fuel return
Old Mar 15, 2016 | 05:36 AM
baZurk's Avatar
why not install the fuel pump now when you are already back there?
Old Mar 15, 2016 | 05:38 AM
liquidgsr's Avatar
Yeah getting back there is a pain. And what kit did you use to for the fuel return conversion? I wish I didn't go over board with mine and do the Full Blown dual hanger kit. Should of just gone with a simple fuel return conversion.
Old Mar 15, 2016 | 05:44 AM
Rays S2k's Avatar
I haven't installed it yet since I don't know the stock fuel pressure
Old Mar 17, 2016 | 09:57 AM
King Tut's Avatar
Originally Posted by TUKES2k
Originally Posted by Rays S2k' timestamp='1457980297' post='23908147
[quote name='King Tut' timestamp='1457980110' post='23908142']
Stock tune should be fine as long as you run the same fuel pressure on the regulator.
OK awesome do you happen to know what the stock fuel pressure is
pretty sure its 43.5... are you changing the pump and injectors?
[/quote]
I'm 100% sure you are wrong. Maybe on an AP1, and you are converting to a return style. The returnless setup on the 2006+ DBW cars requires a very high static fuel pressure.
Old Mar 18, 2016 | 11:10 PM
Junkno's Avatar
guys am trying also trying to convert to return style, and i found the kit by Science of speed which also includes the AEM Fuel Pressure Regulator.
would that be a great option going the supercharger route, or just stay with OEM fuel pressure regulator
Old Mar 20, 2016 | 01:28 PM
camuman's Avatar
Originally Posted by King Tut
Originally Posted by TUKES2k' timestamp='1458009389' post='23908630
[quote name='Rays S2k' timestamp='1457980297' post='23908147']
[/quote]
[/quote]
If going to return style. Ap2 def was 43psi base pressure. Returnless might be higher but you are converting so I don't see how it matters.
Old Mar 21, 2016 | 05:34 AM
King Tut's Avatar
Originally Posted by camuman
Originally Posted by King Tut' timestamp='1458237457' post='23911683
[quote name='TUKES2k' timestamp='1458009389' post='23908630']
[/quote]
[/quote]
[/quote]
It matters because he is trying to run the OEM tune which assumes a returnless fuel pressure of around 63 psi. If you don't supply that fuel pressure, than the injector opening times will be wrong.
Spoolin
Sep 28, 2010 01:08 PM
CTECHs2k
Nov 9, 2008 11:40 AM
s2000turbo
Oct 4, 2004 08:41 PM
dut
May 19, 2004 06:04 PM
KYS2000
Jan 15, 2003 01:05 PM
