CR boost build thread
Old May 30, 2010 | 02:40 PM
08s2000CRbackinblack's Avatar
sounds nice!!! quieter than my invidia 70mm when it was N/A. havent dynoed yet just street tuning myself. i had it boost creep to 10psi ooooppppss still wasnt lean and fell strong a my own i spent less than 15 minutes on, lol. im so happy to have boost again!
one down side is i have the 7.5 psi spring in and it crept to 10 psi at 5000-5200 rpm at like 70 percent throttle so i think im may run into some boost creep :/ when i can make some good runes to see what it crepps up to i will have to decide what to do. may have to go with meth injection if it creeps to much??? idk but it feels stgrong for now goin past 5200. i have vtec kick at 4600 and as soon as it hits it pulles hard for a second before i lift at 5200. i need to get on a dyno soon and get some good pulls. but i can make some good 3rd gear passes on i-4 to get a pretty close tune
Old May 30, 2010 | 02:43 PM
oh yea i had 5 psi at 4000 rpm =) @ 70% throttle on my t3/60 w/3"vband too!!!i cant wait to get it tuned up roght itsgonna have rediculous power all the way to 8500
Old May 30, 2010 | 04:33 PM
StocS2k's Avatar
Sounds Like its going to be at full boost when tuned around 4500...
Old May 30, 2010 | 04:34 PM
StocS2k's Avatar
What are your total list of mods
Old May 30, 2010 | 04:40 PM
AFs2k's Avatar
I like everything except the way you routed that source for the wastegate. Clean that up a bit.
Old May 31, 2010 | 07:30 AM
yea, it was too tight to fit the wastegate under the downpipe so i had to go over. o well ill see what happens when i can go WOT whenever i can get my injectors in. i need little female clips so i dont have to cut the pins of the stock injectors but wont be able to getg them until tomorrow.
my mod list:
pfab topmount turbo manifold
t3/60 w/ 3" downpipe and exhaust
ID1000 injectors
turbosmart 46mm wastegate
hks ssqv ver.3 blowoff valve
3" intercooler piping
intercooler 4" inch thick, 14 high, 27 wide
boost and wideband gauges
walbro fuel pump
competition clutch stage 4 with competition pressure plate
lightweight 11lb. competition clutch flywheel
removed delay valve on clutch slave
Old Jun 4, 2010 | 12:10 PM
spectacle's Avatar
Are you going to be at Real Street tomorrow?
Old Jun 4, 2010 | 06:42 PM
StocS2k's Avatar
^^^Where is that I might go^^
Old Jun 6, 2010 | 01:35 AM
ihiryu's Avatar
very nice! It's always good to see another boosted CR!
Old Jun 6, 2010 | 01:56 AM
getting tuned and dynoed tomorrow on 8spi until i get a boost controller! cant wait
