CT Engineering SC kit
Old Aug 4, 2013 | 03:24 PM
killerbee_vr6's Avatar
Default CT Engineering SC kit
I know that the SOS kit is supposed to have an improved tensioner over the CT kits. How are people doing with belt slip @ 9psi with their comptech / CT kits with the oil fed 1200 blower? Furthermore, how easy is it to get a 9-10psi CT compatible pulley, either from CT or elsewhere? I'm about to order the kit but need to figure this stuff out. Thanks!
Old Aug 4, 2013 | 03:34 PM
lude92_si's Avatar
I run a 3" pulley on my comptech with no slip problems, gator belt 15psi.
Edit, Im running a Novi1000
Old Aug 4, 2013 | 04:25 PM
james0933's Avatar
Yea, get a Reichard racing pulley if you have problems.
Old Aug 4, 2013 | 05:32 PM
chViETnk's Avatar
from what i read, there are no aftermarket pulleys for the new comptech novi 1220 blower unless you modify the the mounting plate. you probably will not be slipping at 9-10psi if you adjust the belt correctly.
Old Aug 4, 2013 | 06:22 PM
I was also under the impression that there are no direct fit higher boost pullies for CT.
Old Aug 4, 2013 | 07:04 PM
chViETnk's Avatar
why not go with the SOS kit if youre looking into running a smaller pulley?
Old Aug 4, 2013 | 07:18 PM
CARB cert will go a long way, don't want the hassle of trying to get smogged
Old Aug 4, 2013 | 07:24 PM
chViETnk's Avatar
you know you will need injectors and standalone ecu to run 9-10psi right? which wont be smog legal anyways.
Old Aug 4, 2013 | 07:37 PM
nah, flashpro and the CARB EO on the mounting plate will cover smog
Old Aug 4, 2013 | 08:20 PM
chViETnk's Avatar
theres 2 carb stickers for the comptech kit, one is for the blower thats on the plate and theres also another one for the fuel lines thats a sticker you are suppose to put on your hood. its gonna depend on the tech that smogs your car. also its questionable if 10psi pollutes enough. i got my car smogged back a few months and they still use the sniffer although i kept reading everywhere that cali isnt doing the sniffer anymore?
