CTSC Aftercooler Flush
Old Sep 7, 2012 | 01:37 AM
BB02s2k's Avatar
Default CTSC Aftercooler Flush
How often do I have to replace/flush my aftercooler?
How do I do it? Can anyone post a DIY?
What should I fill it with water/antifreeze/water wetter?
And how much should I put in? Capacity?
Thanks!
Old Sep 7, 2012 | 09:35 AM
Sideways's Avatar
It should not need a flush ever. You should use distilled water and water wetter. If you are in an area with freezing a little anti-freeze might be indicated.
Old Sep 7, 2012 | 11:55 AM
E4RTH WORM JIM's Avatar
It holds approx 1/2 gallon.
Old Sep 7, 2012 | 12:57 PM
BB02s2k's Avatar
Anyone know if I use the water/water wetter what ratio should it be 50 50?
Old Sep 7, 2012 | 01:02 PM
s2000Junky's Avatar
Typically yes, thats what is recomended.
Fill it so that its a couple inches bellow the fill cap, so when it heats up and expands it has some room to do so, make sure and cycle it through the system so you get the right level. It ends up being about a full bottle of water wetter and the rest water.
Old Sep 7, 2012 | 01:49 PM
s2konroids's Avatar
Shouldn't there only be a 3 caps fulls of water wetter in the whole resvoir?
Old Sep 7, 2012 | 03:27 PM
soulicious's Avatar
I followed the water wetter instructions and if I recall correctly only used 2 or 3 cap fulls.
Old Sep 8, 2012 | 05:35 PM
CoolGuy094's Avatar
Comptech install instructions state to use a full bottle of water wetter and then the rest distilled water.
Edit - Must have been trippin' when I thought I read this... can't find it in the CT instructions.
Old Sep 8, 2012 | 07:01 PM
starrman's Avatar
Step #18: Filling/Bleeding AftercoolerFill the aftercooler with bottled water and Redline Water Wetter (620-028—Not Included ) to Prevent corrosion. A 50/50 water/antifreeze mixture is also acceptable.
Note: If unit is to be used in climate where freezing temperatures may occur, it should be filled with a 50/50 water /antifreeze mixture to prevent freezing and subsequent rupture of aftercooler and potential engine damage.
System uses approx 1/2 gallon fluid.
From my instructions...does not tell you how much water wetter to use? I followed the directions on the bottle...and I think it was 3 caps.
Old Sep 9, 2012 | 09:38 AM
s2000Junky's Avatar
Yeah 3 cap fulls is nothing. I have always used a full bottle and then fill the rest with water, it works out to being close to a 50/50 ratio. Water wetter doesnt heat up like water does, so it keeps the temps down. fights corrosion as well. Just treat it like anti freeze. 3 caps would be almost pointless I think.
