CTSC FMU
What is the vacuum reading on your boost gauge? Does it fluctuate?
Check your clamps to make sure they are nice and tight.
You can also pressurize the system by creating a boost leak tester. Go to home depot and grab a 2.5 white pipe end cap and drill a hole in it to insert a tire valve.
http://www.supramania.com/forums/sho...st-Leak-Tester
Comptech charges $100 for a rebuild of the fmu.
I have an CT FPR on mine and I do not get inconsistent AFR readings, obviously the hotter it gets the richer it will be but still i have only witnessed a .1 (very occasionally .2) difference generally from cold to hot weather, but i run a greddy emanage ultimate which will perform adjustments which keeps the AFR in check.
Did a few more runs..AFR's were still in high 12s low 13s. its about 85~90 degrees out atm. Turned another thread and FPRs dropped to high 11s low 12s. Will see what happens tomorrow. Seems liek afr responds well to the FMU change then gets leaner again..
I think I read a thread of Junky having similar issue?
