CTSC questions
Old Aug 19, 2008 | 09:31 AM
moonwalker's Avatar
Thumbs up CTSC questions
Hi guys,
I am thinking about buying a CTSC from a member. He has a 2005 AP2 with 7psi pulley. I guess my question is will the kit work on my 2002 AP1? Do I need to change anything?
Thanks in advance
Old Aug 19, 2008 | 09:35 AM
stitos2k's Avatar
I don't remember the specifics but I don't think it will work. You can put the ap2 pulley on the ap1 comptech, but I don't think you can just use an ap2 kit on an ap1 car.
Might be wrong though. I had a CTSC 2000 s2k, it was fun. Wish I had kept it instead of buying the evo. The evo sucked so now I'm driving an altima for a couple of years (punishment for getting rid of the s2k )
Old Aug 19, 2008 | 12:47 PM
derek14's Avatar
the kit will work, you're just going to be producing more than 7 psi at 9k rpms with that pulley
Old Aug 19, 2008 | 01:32 PM
raymo19's Avatar
Yep - and you'll need to make sure you're not leaning out the AFR too much.
Old Aug 19, 2008 | 01:59 PM
moonwalker's Avatar
I see. Thanks a lot guys.
I was worried about the stock AP2 FMU won't work on AP1s...
I'd prob just get a stock boost belt.
Old Aug 19, 2008 | 03:43 PM
raymo19's Avatar
No - you need to match the belt to the SC pulley you'll be running. It's hard enough keeping the tension right when they're properly mated.
Old Aug 19, 2008 | 05:08 PM
moonwalker's Avatar
Thanks raymo19 =)
Old Aug 20, 2008 | 11:03 AM
S2KIAL's Avatar
just watch the afr... good luck.. you'll like im runnig an ap1 ct aftercooled kit and im luvn it!
Old Aug 20, 2008 | 01:02 PM
s2000Junky's Avatar
So make sure and install a wide band guage so you can always see what your afr's are doing. $300 is a cheep investment if it means saving your motor. Its the single most important guage to run when fi, everything else comes second in comparison.
You can run a 4.2" pully max with stock fuel injectors and maxing out your fpr. Thats about 6.5 - 7psi. 7psi pully on an ap2 is likely a 4" and will be about 8psi on yours, don't run it. get the proper pulley. The SC kit itself is the same.
Old Aug 20, 2008 | 02:34 PM
raymo19's Avatar
Forgot about the injectors - and the AEM EMS.
It's been a while.
