CTSC vac lines..
Old Nov 11, 2012 | 08:12 PM
kerm1t's Avatar
Default CTSC vac lines..
ive been using a ton of search threads but not finding what im looking for, which is why ive been making so many threads..
My CTSC didnt come with extra vac lines that was on the instruction manual.. are the 20" lines something i need or am i supposed to reuse all the ones thats already on the car?
Old Nov 12, 2012 | 09:55 AM
CoolGuy094's Avatar
I would suggest going to autozone and buying some vac line there. They sell it by the foot and it is pretty darn cheap. That way you can fit it in place and cut to a perfect length.
Old Nov 12, 2012 | 11:46 AM
kerm1t's Avatar
yea i dont mind doing that, But i was told that i can just reuse my vac lines. but i wasnt sure
Old Nov 12, 2012 | 02:36 PM
kerm1t's Avatar
anyone?
Old Nov 12, 2012 | 03:59 PM
CoolGuy094's Avatar
You will need additional vac line to go to items such as the BPV/BOV, FPR, and so forth. Your stock vac lines will not be enough. You should go to autozone and buy enough footage to do what the manual suggests. You may be able to reuse some of the stock lines, but I ended up scrapping a good bit of my stock lines after the install.
Old Nov 12, 2012 | 04:34 PM
steven975's Avatar
The cheap roll of 4mm hose Autozone sells would be enough for 3 cars, I bet.
Old Nov 12, 2012 | 05:41 PM
kerm1t's Avatar
cool. will do!
lastly, can anyone tell me if there is a difference between the emission hose, and fuel injection hose? i want to make sure i grab the right one the first time..
thanks
http://www.autozone.com/autozone/acc...fier=4954_0_0_
http://www.autozone.com/autozone/acc...er=240843_0_0_
Old Nov 12, 2012 | 05:44 PM
s2k manic's Avatar
when i put mine together i bought 30' of nylon braided vacuum line that BMW and Mercedes use on eBay for 35-40 bucks. i use to work at a Honda dealership and half of the older vehicles the came in running rough were either pcv,cap rotor or vacuum line deterioration and sense the control valve is mounted below the sc i didn't want to deal with it in a few years just depends on your taste. fyi 30 ' was enough line to replace all the vacuum lines in the car, run to boost gauge water meth controller even the secondary map sensor for the e manage good luck there is a diy on installing comptech supercharger i forget were its located but it would help answer some questions good luck with your install
Old Nov 15, 2012 | 03:35 PM
kerm1t's Avatar
can anyone tell me if there is a different between these two hoses? one is emission hose and another injection hose?
SPECIAL-OPS-S2K
May 7, 2007 02:48 AM
Katyushin
Dec 14, 2006 11:58 AM
NFRs2000NYC
Jan 28, 2005 08:40 AM
The Reverend
Jul 22, 2004 06:03 PM
Gloffer
Feb 10, 2003 03:42 PM
