Curious about this setup
Old Dec 9, 2007 | 08:50 AM
bruthaboost's Avatar
Default Curious about this setup
So I'm slowly putting together my own "kit", however I'm looking at the Greddy kit and it looks good for my power goals. I've been thinking about selling what I have and just getting that.
The only thing stopping me is that I haven't seen/read anyone trying my potential new setup. So far I have:
FMIC
Injectors
divided tubular manifold
wastegates
ebc
gt3071 (going to pick up the .78 atp divided turbine housing)
bov
3mm hg
clutch/pp/flywheel (already installed)
oil feed/drain
filter relocator
gauges, clamps, odds/end/etc
alcohol injection, SMC kit (still debating if I want to install this. had it on a previous setup. Refilling is a pain)
Only things left are my piping, exhaust, and fuel/ignition control. I have my old welding setup, it's just I'm really short on time and a bolt on kit would make things very fast and easy.
I'm really curious how much I can cut the lag with this setup. Appreciable boost should be damn near right off throttle. I'm going for 350-400 whp with as little lag as possible.
What do you all think of this potential setup?
Old Dec 9, 2007 | 02:26 PM
cij911's Avatar
FMIC
Injectors
bov
3mm hg
oil feed/drain
filter relocator
A 30R + Alk or Meth should easily be able to net you 400whp. That said, if your goal is 350 - 400whp, you could actually go a little smaller than the 30R and get better low end response. If you go the Alk or Meth route, I would highly recommend a great failsafe (e.g. Zeitronix wideband + boost solenoid) -- this will ensure that if your SMC kit ever fails you won't blow up your engine....
Good luck....
PS -- You could also give our Rotrex S/C kit a look ....
chris2k03
Jun 14, 2011 08:20 PM
gazman
Australia & New Zealand For Sale and Wanted
20
Feb 16, 2009 11:52 AM
TookayS2K
Aug 5, 2008 01:32 AM
FurY
Jun 13, 2007 02:30 PM
StaticS2K
May 9, 2006 10:38 AM
