custom turbo kit
Old Jan 13, 2008 | 05:39 PM
03silver2000's Avatar
Default custom turbo kit
i am aware of all the parts needed to install a turbo kit on my03 and i have installed a turbo kit b4 i am looking for about 400 hp and i plan to get a 3mm headgasket...but would like to hear expierences and recommendations on turbo parts. I know im going to go with a HKS BOV
any feedback will be helpful...thanks!
Old Jan 13, 2008 | 05:41 PM
also i forgot to mention that i would like to get a electronic boost controller and be able to put out 400 hp on high boost and about high 2's 300 max on low boost considering the fact that this is my whenever there is nice weather DD
Old Jan 13, 2008 | 06:01 PM
Reborn56's Avatar
EBC look no further
http://www.rx7store.net/product_p/profecspec2.htm
Old Jan 14, 2008 | 08:23 AM
passmans2kny's Avatar
if ur getting aem ems, consider the aem tru boost gauge/controller, yo reborn i had that boost controller on my rx7, it was good stuff
Old Jan 14, 2008 | 10:26 AM
2big4aS2000's Avatar
IF - USING AEM EMS, ALLOW THE EMS TO SWITCH HI-LOW WITH A LITTLE TOGGLE SWITCH AND SOLINOID....
Old Jan 14, 2008 | 12:09 PM
SPECIAL-OPS-S2K's Avatar
How is this done? I have the AEM 1052... what else would I need to buy to be able to use a switch to change fuel maps and boost levels?
Old Jan 14, 2008 | 12:36 PM
just keep a laptop in the car with u
Old Jan 14, 2008 | 01:13 PM
NOT A PROBLEM, US A SPRING RATE IN YOUR WASTE GATE TO SET LOW BOOST, THEN WHEN YOU WANT HIGH BOOST, FLIP A SWITCH, THE SWITCH JUST GROUNDS A PIN GOING TO THE EMS, THIS IN TURN PULSES THE WASTE GATE WITH SOLINOID TO GET HIGHER BOOST. THIS IS ALL SETUP IN AEM - ANY TUNER THAT KNOWS AEM SHOULD BE ABLE TO DO THIS.
Old Jan 14, 2008 | 01:52 PM
rob!'s Avatar
if you are looking for only 400whp max then you dont really need the 3mm headgasket. I suggest going with AEM EMS. as for the other parts, I like the inline pro manifold the best, Pfab is nice also. turbo and all that other stuff is really up to you. If you have built turbo cars then you should already know what you like/dislike as far as turbo, wastegate, boost controller, intercooler and dont need our help picking that stuff out.
Old Jan 14, 2008 | 01:59 PM
gotswap's Avatar
LOL
