DBW Return Fuel System
Old Sep 23, 2009 | 05:13 AM
EMR01's Avatar
Default DBW Return Fuel System
Has anyone tried this type of system on there DBW? I searched but nothing really came out.
(Sorry but MS paint was all I had)
You tap the fuel assembly add a 8AN bulkhead as your feed line,you coonect your walbro to the bulkhead and use your oem feed as return.Most rsx users do this when going FI.It looks like this:
What it looks like under the car:
Old Sep 23, 2009 | 05:21 AM
ILoveMYHonda1984's Avatar
I have a MY06 and had thought about doing this during the winter s I can run e85 on the car. I currently have a boost a pump which increases the voltage to the pump above 3psi of boost up to 20V. It works like a amplifier for a car stereo. I havent run out of fuel yet but am only pushing 400 or so to the wheels. I will have to upgrade to the 1200 Paxton to need this mod. I am maxed out on the 1220 so the next step will be quite costly.
Keep us updated if you try it!
Old Sep 23, 2009 | 10:24 AM
PsykotiK's Avatar
u wont need the return fuel system when you are upwards 500 wheel
Old Sep 23, 2009 | 11:31 AM
kutsujula's Avatar
You max out a single walbro with the non returnless setup with 1000cc injectors around 475whp I believe.
Old Sep 23, 2009 | 12:37 PM
EternalLx's Avatar
but if your planning on E85 then yes you need a return line
rob!
Jul 23, 2009 11:53 AM
2QYK4U
Nov 20, 2007 10:17 AM
cock_diesel
Aug 23, 2007 05:56 PM
cock_diesel
Aug 18, 2007 01:30 PM
DLS2000
Aug 30, 2001 11:53 AM
