Direction of coolant flow / stock heat exchanger Q
First question, does anyone know the direction of flow for the engine coolant shown in these two pictures?
Front of engine block:
Side of engine block:
I ask this because I'm planning on reinstalling the stock oil heat exchanger which brings me to my next two questions. Does direction of flow matter in the stock oil heat exchanger? Also should I route it before the turbo or after the turbo?
Much appreciated
Much appreciated
i don't know the flow of the coolant, but would be very curious to see the influence of the stock coolant oil cooler in lowering temps! i currently have this setup but dont have a oil temp sensor or the before/after effect of the coolant running through the oil filter to see if it helps!
I would personally run it before it goes to the turbo, as i see the oil temperature being more important than the temp that goes to the turbo. Considering the price of a new motor compared to a new turbo!
After talking to pat, stock oil heat exchanger, lower temps for the fan turning on, and MAYBE a larger radiator should solve the oil heat problems.
With pats setup, he has aftermarket rad, lower fan temps, stock oil heat exchanger, and a small aftermarket oil cooler, his oil temps ONLY get to 170F at full load
, actually TOO low lol
Originally Posted by Soul Coughing,Aug 23 2008, 09:30 AM
you need to use a thermostat on the oil cooler to bypass the oil cooler when its cold out, so as to allow your oil to reach its operating temperature!
Bump for info on coolant flow...
NP Jon
https://www.s2ki.com/forums/index.ph...f=133&t=232925
Had this one bookmarked, plenty of good info about cooling... fperra and davepk confirm the flow.
riceball777
Oct 19, 2013 08:34 AM
Silver S2k4
Feb 21, 2008 01:14 PM
