DIY Modified Crank Pulley
Old May 19, 2007 | 07:24 AM
aero3685's Avatar
Default DIY Modified Crank Pulley
Any tips on drilling/tapping the OEM crank pulley for the s/c pulley?
Im sure it cant be much harder than just centering and levelling up the pulley, and drilling with a drill press so the holes are straight, then tapping them out right?
It'll be for a Vortech system. Any input ASAP would be greatly appreciated.
Old May 19, 2007 | 04:24 PM
m R g S r's Avatar
have a machine shop do it...if its not perfectly centered it will un balance your entire rotating assembly.....bye bye main bearings!
Old May 19, 2007 | 05:36 PM
AusS2000's Avatar
I had mine done by a friend who has a nice mill/drill setup. Just measured up and programmed and it did the holes at 60 degree increments.
Might as will do it properly.
Old May 20, 2007 | 05:24 PM
Slows2k's Avatar
You need someone competent with a drill press and tap. Machine shop is the best bet. I've done one myself.
Old May 20, 2007 | 05:26 PM
aero3685's Avatar
Yeah, I think we will just be finding an already drilled one.
I forgot that little side effect of the main bearings
Old May 21, 2007 | 07:43 AM
Bmancsu80's Avatar
I drilled and tapped mine, no problems so far with over 3k miles. The vortech adapter pulley will line itself up on the crank pulley, or at least mine did.
vadik_s2k
Nov 30, 2016 04:15 AM
EOE
Jul 29, 2012 06:32 AM
AirWick219
Jul 5, 2010 12:57 PM
Moddiction
Dec 2, 2009 07:47 PM
skibum
Jul 27, 2005 09:01 PM
