Do all Vortechs using the black box run lean?
Old Aug 4, 2009 | 10:17 AM
JS2k.com's Avatar
Sponsor
Default Do all Vortechs using the black box run lean?
I've been reading that Vortechs run lean with the black box. Is this the general consensus? I've also read of people running it with the blackbox since they bought it.
Is there any other solution I should consider? I don't care for a VAFC because I would rather just buy the Emanage Ultimate if I do have to buy something, so I can upgrade pulleys in the future.
Thanks!
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Aug 4, 2009 | 10:26 AM
stitos2k's Avatar
Personally I think the running lean thing was more from additional aftermarket parts (headers, exhaust, blah, blah). I wouldn't use an emanage as a paper weight though, not even the emanage ultimate.
Old Aug 4, 2009 | 10:41 AM
s2000isu's Avatar
The black box has nothing to do with the fuel. Like I said if its lean you need to turn the fmu up.
Old Aug 4, 2009 | 10:51 AM
stitos2k's Avatar
That too.
I always forget about that thing.
Old Aug 4, 2009 | 11:23 AM
JS2k.com's Avatar
Sponsor
Oooh, okay. I did some more research:
$40 for a piece of plastic? Is this what you mean by turning the FMU up with the recalibration kit?
edit: apparently you can do the same thing with a washer replacement.
__________________
_________
Old Aug 4, 2009 | 11:45 AM
stitos2k's Avatar
Eh, pretty sure on my comptech it was just a screw. Give it a turn to add or remove fuel.
Old Aug 4, 2009 | 12:03 PM
s2000isu's Avatar
Yup stito I was confused the comptech is the one that you can adjust not the vortech.
Old Aug 4, 2009 | 12:24 PM
JS2k.com's Avatar
Sponsor
So back to the idea of Emanage Ultimate since it's not adjustable?
__________________
_________
Old Aug 4, 2009 | 12:29 PM
devs2k's Avatar
The Emanage Ultimate will work just fine, provided you have a good tuner.
Old Aug 4, 2009 | 12:32 PM
Skatethesea's Avatar
I brought the Emanage to my tuner and he refused. He wouldnt tune my car til I had an AEM EMS.
