View Poll Results: Do you coat these parts
Thermal coating on turbo housing
50.00%
Thermal coating on exhaust manifold
75.00%
Thermal coating on downpipe/midpipe
62.50%
Thermal coating on piston tops
25.00%
Thermal coating on combustion chamber/valve faces
0%
Thermal coating on exhaust port
0%
Friction coating on piston skirts
25.00%
Friction coating on valve stems
0%
Oil shedding on crank, rods, cylinder block
0%
Heat emitting on radiator, oil coolers, intercooler
12.50%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Do you use coatings in your engine?
I've used SwainTech and regular ceramic... I don't do that anymore as I don't think I really does much but lighten the wallet. I'll use cheap local ceramic if the hot side is not stainless and can rust, but then follow up with a turbo blanket. On the pipes, I like to use Inconel shielding to control heat in the engine bay.
I'd be rather surprised if it doesn't make a meaningful difference in temps. Did you take measurements with an IR temp tool?
