Does heat affect a tune this much
Old May 26, 2014 | 07:21 PM
That Guy 1987's Avatar
Default Does heat affect a tune this much
What's going on guys? Went to get my car retuned and wasn't to thrilled with the numbers granted i know we all say the dyno is a tool. Now I made 439 at 13 psi late November last year about 50 degrees outside. Went back today and made 400. It was about 85 outside here in FL. Question I have is does or will heat affect horsepower this drastically? I read for every 5 to degrees 10 dropped you make 1 percent more horsepower. Tuner always mentions that his dyno dynamics reads low next to a dyno jet.
Old May 26, 2014 | 07:36 PM
baZurk's Avatar
Were you on two different dynos? Heat as well as humidity can rob a lot of power of a FI car
Old May 27, 2014 | 03:02 AM
No, same tuner and same dyno.
Old May 27, 2014 | 03:16 AM
JJAUTOWERKS's Avatar
Former Sponsor
Jesus!
Old May 27, 2014 | 06:52 AM
KaNgArOo's Avatar
That sucks. But 50 degree compare to 85 degree is a big difference. I'm also going to assume humidity was up as well. So yeah, i would blame the heat/humidity.
Old May 27, 2014 | 06:53 AM
KaNgArOo's Avatar
How was your Boost pressure? Was is still reading at 13psi?
Old May 27, 2014 | 07:01 AM
CoolGuy094's Avatar
My question as well. I would expect a PSI loss at higher ambient temp and humidity, which would lead to the power loss.
Old May 28, 2014 | 10:32 PM
Forcedbird's Avatar
Compression test??
Old May 29, 2014 | 06:44 AM
yamahaSHO's Avatar
Boost pressure should not change.
Not only will heated air make less power, but various ECU temperature compensations could be in play by removing timing or adding fuel. Ideally, a correction factor takes care of the former, where the latter would need to be handled by the tuner.
Old May 29, 2014 | 06:49 AM
CoolGuy094's Avatar
Whoops, I guess I was thinking of a SC setup where boost is determined by pulley size, not by wastegate, controller, etc.
