Drag Radials just came
Old May 14, 2008 | 11:01 AM
USMCAP1's Avatar
Default Drag Radials just came
Alright i have finally got my drag radials and mounted them on my AP1 wheels for the track. I run AP2 V2 daily. They are BF Goodrich G-Force T/A Drag Radials 255/50-16. I am still running my stock diff so i dont even think about launching. I spin 1-3rd on the track w/ street tires. Does anyone have any advice or things i should know about the drag radials, what to expect? Also what is a good PSI to run in the tires? Obviously more traction, but should i gently put it into gear or just keep power shifting and hold on? Anything will help. I have never driven on drag radials before.
Old May 14, 2008 | 02:33 PM
Spoolin's Avatar
I run around 22 psi on the street with my 275/40/18 DR's and on the track, if I ever make it with them, probably around 18 psi.
Old May 15, 2008 | 05:04 AM
USMCAP1's Avatar
alright cool. Right now i am on 25psi. i was thinking around 17psi for the track. But i would rather just see what has worked for others.
Old May 15, 2008 | 05:16 AM
PrOsPeCt S's Avatar
my friend has these tires on his 99EK coupe with a K on boost making 340rwhp@12psi and we run the tires @ 10psi at the track and the tires hook up pretty dam good.
Old May 15, 2008 | 05:49 AM
USMCAP1's Avatar
Sweet! i bet that thing moves! i love the K series. I am running this Saturday, so i think i am going to start out at about 17 and if need be let more air out as i keep running.
Old May 15, 2008 | 06:02 AM
btstone84's Avatar
I run mine around 16 to 17 psi and i have the same exact DRs you have
Old May 15, 2008 | 06:43 AM
USMCAP1's Avatar
i still have a stock diff. I am scared to heat them up at the water box in case i catch and brake something. You think they will do ok if i dont go through the heat cycle, especially b/c i am not launching.
Old May 15, 2008 | 07:06 AM
Spec_Ops2087's Avatar
DRs + stock diff = done. Unless you don't mind breaking it, I wouldn't heat them up if I were you.
Old May 15, 2008 | 07:27 AM
USMCAP1's Avatar
thats what i am thinking. People are telling me that i will be safe if i am in the water but i dont feel to confident about it. I will just drive around the water box like i usually do. I plan of doing the diff kit soon, but in the mean time this is my daily.
Old May 15, 2008 | 08:06 AM
btstone84's Avatar
f you are worried about your diff, why did you buy drag radials?
