Drill and Tap
Old Aug 2, 2005 | 07:55 PM
AusS2000's Avatar
Default Drill and Tap
Just wondering what size hole a drill to tap a 1/8 BSP thread.
I bought a 1/4" fitting for my wastegate line and it is a threaded 1/8 BSP. I couldn't find a tap for it anywhere. Got home and my metric tap and dye kit has a 1/8 BSP tap and dye. Miracles never cease to amaze me.
I'm sure I can work it out but I'd rather just know the rule of thumb up front before I start drilling into my turbo.
Old Aug 2, 2005 | 08:14 PM
Slows2k's Avatar
I believe it's a "R" in a letter drill.
Old Aug 2, 2005 | 08:26 PM
AusS2000's Avatar
Sheez, I've heard of Metric, Imperial, NSP, BSP and many others, but never "Sesame Street" this drill bit brought to you by the letter "R".
Old Aug 2, 2005 | 08:31 PM
Slows2k's Avatar
Sorry, I was just looking at a drill chart tonight, from tapping a 1/8 NPT EGT bung.
Letter drills are farly common is Machine shops in the Good Ol' USA.
I don't have the chart in front of me, otherwise I could tell you the fractional size.
Old Aug 2, 2005 | 08:41 PM
AusS2000's Avatar
I found this:
http://www.engineersedge.com/drill_sizes.htm
R appears to be 0.3390. I assume that is inches so about 8.5mm. And that is pretty close to the diameter of the threaded section.
Cheers
Old Aug 2, 2005 | 09:01 PM
AusS2000's Avatar
Just did a test and 9mm is about right.
Old Aug 3, 2005 | 04:11 PM
AusS2000's Avatar
9mm is probably borderline When you tap it there isn't much bite so is probably bigger than you should use. Will be fine for a pressure tap but not for anything structural. I'd say try 8.5mm and let the tap do the work.
detoxclinic
Feb 27, 2016 11:53 AM
lude92_si
May 13, 2014 03:14 PM
lude92_si
Nov 29, 2013 06:13 AM
s20004lifehomes
Mar 10, 2011 11:10 AM
AndyDoh
Jun 17, 2003 08:07 AM
