Driving without vortech timing box
Old Nov 22, 2006 | 09:43 AM
TheCarGuy2021's Avatar
Default Driving without vortech timing box
Hey guys I've finished everything for my vortech install, and through testing I have figured out that my black timing box is not working. The car will not start when it is hooked up, I have tried numerous times solidering, crimping, following the diagram, following written and nothing works. The car will however start and drive with the map black box hooked up. So I figured the car could be driveable. I drove to the local speedway and put some cam2 110 octane leaded racing fuel in it (I don't have a cat anyway) and I figured this would help resist detonation. So my question is until I get a means of retarding the timing (new box), would this be safe to drive around? My S is my daily driver and only car so I need to get around.
Thanks guys.
Old Nov 22, 2006 | 09:45 AM
AusS2000's Avatar
Depends. Can you resist the temptation to boost?
Thought not.
Old Nov 22, 2006 | 09:50 AM
Sideways's Avatar
Actually, it just pulls up to 3 degrees out so if you have enough octane....you can see where this is going.
I will admit I took it up once on the way home, but stopped myself from doing so again. What would the ill effects of doing so be?
Old Nov 22, 2006 | 09:51 AM
Sideways, that's exactly what I wanted to hear!
Old Nov 22, 2006 | 09:54 AM
Ray K.'s Avatar
the effects could be that pulling 3 degrees of timing isn't enough, you detonate like crazy and lose your motor. I would resist temtation to boost to be on the safe side if I were you. You're probably ok, but why risk it.
Old Nov 22, 2006 | 09:56 AM
CourageOO7's Avatar
Yeah, you can drive it around town as much as you want. I personally wouldn't risk boosting until you get the new box...even if 110 octane (or 120 for that matter) was safe enough. Is it worth it for a couple pulls?
Old Nov 22, 2006 | 09:59 AM
Aww shucks (puts keys back in basket)
Better safe than blowing something up.
Old Nov 22, 2006 | 08:17 PM
Kwando's Avatar
i have a vortech black box that i am no longer using... PM me an offer.
Old Nov 22, 2006 | 11:04 PM
icemans2k02's Avatar
so you finally figured what it was. good
